ZM Port Numbers
jplamb13
ZM Port Numbers
Post by jplamb13 » Tue Dec 10, 2013 9:52 pm
Hi All,
I have got ZM setup and it works great on port 80 but i am wanting it on a different port, i have set up apache to listen to port 81 as well , from this i can load the ZM console but when ever i load a live feed it does not work on port 81 but does on port 80.
on port 81 it opens the new window but only shows a image place holder, as though it can not access the feed,
does anybody have any ideas?
many thanks
PacoLM
Re: ZM Port Numbers
Post by PacoLM » Wed Dec 11, 2013 8:23 am
Maybe you missed something, this is what I did to use another port in apache (taken from somewhere in this forum):
1- edit /etc/apache2/ports.conf, then change both "NameVirtualHost *:80" and "Listen 80" to the new port
2- edit /etc/apache2/sites-enabled/000-default and change "<VirtualHost *:80>" to reflect the new port
3- restart apache "service apache2 restart"
Hope it helps,
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
johnaaronrose
Re: ZM Port Numbers
Post by johnaaronrose » Fri Mar 02, 2018 1:21 pm
If you want to check that Apache is now listening to port 81, try http://127.0.0.1:81 in your browser and you should get the Apache default page.
John
