No Control Tab for FI9821W on Monitor Setup
chaoticmachinery
Post by chaoticmachinery »
I don't have a Control tab for my FI9821W as shown in http://www.zoneminder.com/forums/viewto ... it=FI9821W.
I did go through the setup and seen that in the 1.26.4 version I recent downloaded all of the steps were already implemented. The perl module was there, the change to controlcap.php, and change to the Controls table. I followed the screen shots shown in web page. Still no Control tab?
BTW this is a brand new install of ZoneMinder.
Any suggestions?
Thanks,
CM
chippy99
Re: No Control Tab for FI9821W on Monitor Setup
Post by chippy99 »
If you go into options from the main screen and then select the system tab, near the bottom is OPT_CONTROL, enable this and you should then see the control tab that is missing.
chaoticmachinery
Thank you.
