If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
fadjar340
Post
by fadjar340 » Fri Jan 02, 2009 6:46 am
Dear All,
I want to help translating ZM to Arabic.
Is there any documentation to do this?
Also is it possible have multi language in the ZM?
Regards,
Fadjar340
cordel
Post
by cordel » Fri Jan 02, 2009 7:08 am
The sticky above sort of explains it.
fadjar340
Post
by fadjar340 » Fri Jan 02, 2009 3:40 pm
As I understand the files of the language based on English and everybody read the test from left to right.
Since the Arabic language should read from right to left, is ZM have this feature? I mean change the reading direction...
Regards,
Fadjar340
cordel
Post
by cordel » Fri Jan 02, 2009 5:03 pm
I honestly could not say as I'm not at all sure.
You might have a look in web/zm_lang_en_gb.php
kie1988
Post
by kie1988 » Mon Aug 27, 2012 5:21 am
Hi
where you able to translate to Arabic?
beiber
Post
by beiber » Thu Sep 19, 2013 6:00 am
Yes very easiest and simple way is Google translator and you can also try Babylon translator.
Today is the tomorrow you worried about yesterday.. for tomorrow never comes.. live today!!!
