Hi guys,
long time no posting
Just done a fresh install of 1.26.3 using the excellent puppet script - but a couple of minor problems which maybe related
During the install puppet reported it couldn't find fqdn but the install seemed to work ok.
However I suspect zms isn't working / installed as I get this error in the log
2013-09-14 20:05:11.988128 web_js 2034 ERR getCmdResponse stream error: socket_sendto( /tmp/zm/zms-487548s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=event
2013-09-14 20:05:11.903939 web_php 2034 ERR socket_sendto( /tmp/zm/zms-487548s.sock ) failed: No such file or directory includes/functions.php 2323
2013-09-14 20:05:00.467033 web_js 1934 ERR getCmdResponse stream error: socket_sendto( /tmp/zm/zms-068887s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=event
2013-09-14 20:05:00.402088 web_php 1934 ERR socket_sendto( /tmp/zm/zms-068887s.sock ) failed: No such file or directory
plus I'm not sure where or even if camboloza is installed and there's no option for a montage display.
Maybe these issues are all related ?
FYI just using regular analog cameras with a BT878 board
Any pointers ?
Regards Tim
problem with cambozla, streaming and montage
Re: problem with cambozla, streaming and montage
ok as usual I've fixed the problem - I had cambozola installed in the wrong place - it should have been in usr/local/src/zoneminder/web or at least putting it there makes it work or in /var/www/zm
I can't run a montage as currently I only have one monitor set up.
However logging in as admin and adding another monitor fixes that problem.
Too much beer I guess is the culprit here...
