Note that the only 100% guaranteed way to update any zoneminder database to a newer version is to run it exactly like so:
sudo zmupdate.pl --user=root --pass={mysql_root_password}
WARNING: If you run zmupdate.pl by simply executing "zmupdate.pl" with no options from the command line, the upgrade to 1.26 will not be successful even if zmupdate does not report an error.
Unconfirmed symptoms of an improperly run zmupdate include the following:
- All events disappear after zmupdate is run
- All monitors in black & white
- No 32bit color option
