hi,
I would like to ask how to add Panasonic BL-C10 to ZoneMinder.
Assume the ip addr of cam is 192.168.1.100
Login: administrator
Password: abc123
What should I fill for the following fields in "Source" ?
Remote Host Name
Remote Host Port
Remote Host Path
Panasonic Camera BL-C10
Remote Host Name: 192.168.1.100
The port is more than likely 80
Remote Host Path (dependeing on your install)
/cgi-bin/zms?mode=jpeg&monitor=2&scale=100&maxfps=1&user=administrator&pass=abc123
or
/cgi-bin/zm/zms?mode=jpeg&monitor=2&scale=100&maxfps=1&user=administrator&pass=abc123
Of course you may wish to set the FPS higher as The above example is set to 1.
Cheers,
Cordel
or
Cheers,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
- zoneminder
- Site Admin
- Contact:
thanks a lot "zonemider", I can add my BL-C10 cam to ZM now. Actually BL-C10 uses same program as KS-HCM10, so most of the paths are same.
By the way, I have another problem on "control". I used zmcontrol-kx-hcm10.pl for my cam, pls advise on the following fields under "control"
Control Type : I chosen KX-HCM10
Control Device: I leave it blank
Control Address: I typed "administrator:abc123@192.168.1.100"
But it cannot control movement of cam.
I tried http://192.168.1.100/nphControlCamera?D ... n=PanRight
which can control the cam to right successfully. That means the control command of KX-HCM10 should be same as BL-C10.
- zoneminder
- Site Admin
- Contact:
