newbie: exported video pixely and coarse
neuronetv
Post by neuronetv »
centos 6.3 server running zm 1.25
I can export an event to avi file but the resulting video is coarse and pixelated, lacking the sharpness and definition of the original frames, it often makes faces unrecognisable. I can get round this by exporting the event at 3 x normal size and them reducing the avi file again but this seems a strange way to get a decent video from an event. Is there some setting I can adjust so the exported avi is as good as the original event?
PacoLM
Re: newbie: exported video pixely and coarse
Post by PacoLM »
Try this settings in Configuration::Images:FFMPEG_OUTPUT_OPTIONS:
-r 25 -qscale 1
Hope it helps,
PacoLM
neuronetv
Post by neuronetv »
thanks for your response PacoLM, that -r 25 -qscale 1 did the trick. Exported videos are now as good as the original.
chriswiggins
Post by chriswiggins »
The other alternative is to add the following to the output options: -b 20000000 which makes the bitrate of the output video 2mbit
