log errors opensuse 12.2
libbi
Post by libbi » Fri Sep 21, 2012 11:36 am
i have installed ffmpeg 0.11.1-1.4 and zoneminder 1.25.0-36.1 from repositories
after run console i going to logs /zm/index.php?view=log
i can see "no zmwatch.pl" but this file is stored in /usr/bin help!
2012-09-21 19:23:51.354790 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:23:41.284100 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:23:31.208080 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:23:21.136020 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:23:11.071960 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:23:00.994370 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:22:50.882460 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:22:40.811020 zmwatch 4294 ERR Can't get shared memory id '7a6d0001', 1: No such file or directory zmwatch.pl
2012-09-21 19:21:54.325160 zmdc 4189 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2012-09-21 19:21:54.259769 zmc_m1 12901 FAT You must have ffmpeg libraries installed to use remote camera protocol 'rtsp' for monitor 1 zm_monitor.cpp 2428
2012-09-21 19:21:54.112660 zmdc 12901 INF 'zmc -m 1' started at 12/09/22 03:21:54 zmdc.pl
2012-09-21 19:21:54.112550 zmdc 4189 INF 'zmc -m 1' starting at 12/09/22 03:21:54, pid = 12901 zmdc.pl
2012-09-21 19:21:54.033820 zmdc 4189 INF Starting pending process, zmc -m 1 zmdc.pl
Carrier82
Re: log errors opensuse 12.2
Post by Carrier82 » Fri Sep 21, 2012 11:46 am
It may be that the OpenSuse repository is not compiled with ffmpeg support enabled.
libbi
Post by libbi » Fri Sep 21, 2012 2:33 pm
Carrier82 wrote:It may be that the OpenSuse repository is not compiled with ffmpeg support enabled.
installed from:
ffmpeg - packman.inode.at/suse/openSUSE_12.2/
zm - liquid-co.de/pub/suse/repositories/12.2
Carrier82
Post by Carrier82 » Fri Sep 21, 2012 7:26 pm
You need to install zoneminder version that has ffmpeg support enabled (MP version?). The stock opensuse version probably doesn't have. Or you may compile zoneminder yourself with ffmpeg enabled.
http://forums.opensuse.org/english/othe ... inder.html
libbi
Post by libbi » Sat Sep 22, 2012 2:04 am
what different MP or not MP?
Carrier82
Post by Carrier82 » Sat Sep 22, 2012 11:54 am
I googled this for you and it is in the forum link I pasted. " two versions of the RPM exists: ZoneMinder and ZoneMinder-MP. ZoneMinder-MP is build against ffmpeg (from the packman repository) and the other one only requires the official openSuSE packages." Never used Suse so my knowledge ends here.
monex
Post by monex » Sat Sep 22, 2012 4:52 pm
could you provide more informations, how are the cams connected to ZoneMinder? Have you completed all steps of http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE after installing the RPM. Have you already tried to adjust the shared memory settings as described here http://www.zoneminder.com/wiki/index.ph ... esolutions. ?
Hope this helps
