Hello
I have 5 bosh ndc 225 pi cameras and I am tring zoneminder in a virtualized linux server (CentOS 5)
I compile zoneminder from sources and installed ffmpeg from rpms and these are the results:
4 cameras work, but i have very events from lost signal and one camera dont work, i cannot obtain the feed from that camera and are configured with the same form in zm:
The feed its obtained from
/snap.jpg?JpegSize=M&JpegCam=1&JpegDomain=5035302&counter=1346964557642
They work with only the firts two parameters JpegSize and JpegCam
Have you experience with that model of cam and zoneminder? And have you configured these cams with rtsp?
I cant put the imgs here: the site dont allow me. OMG
I can view the feed with vlc only passing the command vlc rtsp://ip
Greetings
Bosch ndc 225 pi
Re: Bosch ndc 225 pi
The image are here
subirimagenes dot c0m imagen-camerazm-7974868 dot html
Not familiar with the make and model, but
- Make sure the fifth camera works when you put the direct snap.jpg path in browser - if not and others do, it's somehow broken.
- You can configure Zoneminder to use monitor type ffmpeg, then you can put the path to direct stream in rtsp:// format
- Check the logs! You might be running out of shared memory, one possible reason for fifth camera not working.
