Hello.
I've installed ZoneMinder v1.25.0 via the Ubuntu 12.04 repositories and all seems to be working great, except one major, important function.
The whole setup has been running for awhile, without any apparent problems. It's connected to an wirelesss IP camera.
The issue is that when the power to the IP camera cuts of / somebody cut the power cable, ZoneMinder doesn't create an event at "Signal lost".
It does however create an event at "Signal reacquired", which is a little too late... Until that the camera is blind and ZoneMinder doesn't care..
Both "Signal lost" and "Signal reacquired" does show up in the log when I kill and then turn on the power to the cam, but again, event isn't created on signal lost, so making a filter to send me an e-mail doesn't work (it does however work on "Signal reacquired".)
I've tried re-installing ZoneMinder without any luck.
Please help, without this function the whole setup is vulnerable.
Jan D.
"Signal lost" doesn't create an "event"-major security issue
Re: "Signal lost" doesn't create an "event"-major security i
zoneminder records video. If the signal has been lost then there is no video to record so no event is generated.
Your best option is to install some monitoring software such as Nagios (http://www.nagios.org/). This will monitor any number of IP cameras and alert you if/when the network loses contact with them.
Its by design. If there is no signal, there is nothing to record.
mastertheknife
mastertheknife
Kfir Itzhak.
I'm sorry to hear that... I really thought that an event or any other form for warning would be generated when a camera is disabled. (must be doable)Paranoid wrote:zoneminder records video. If the signal has been lost then there is no video to record so no event is generated.
Your best option is to install some monitoring software such as Nagios. This will monitor any number of IP cameras and alert you if/when the network loses contact with them.
It is in the zoneminder log, so it's strange that it's not possible to get notified when that happens....I mean..isn't that of most importance!?
I'll check into that link (nagios), but i'm not a fan of running lots of additional services to get done what should be done by THE service in the first place.
This NEEDS to get implemented.
I'll propose this to the developers.
Thanks for the response!
Hello JanD,JanD wrote:I'm sorry to hear that... I really thought that an event or any other form for warning would be generated when a camera is disabled. (must be doable)Paranoid wrote:zoneminder records video. If the signal has been lost then there is no video to record so no event is generated.
Signal loss, Ir-defects and even "Blue Mute" is detectable with the help of an extra package (ImageMagick)
see http://www.zoneminder.com/forums/viewto ... 29&t=19553
Kind regards, Christo
I can attest to the fact that signal lost can indeed become detectable. I've had that happen a few times with my wifi camera - it has a few blips here and there and events are always created for that (though I created a filter that kills those notifications).
Hello McFuzz,McFuzz wrote:I can attest to the fact that signal lost can indeed become detectable. I've had that happen a few times with my wifi camera - it has a few blips here and there and events are always created for that (though I created a filter that kills those notifications).
Always nice to know that posts are read!!
The only problem with detecting Signal Loss with standard ZoneMinder features is that youll have to be aware that the camera('s) should run in a detection mode!! If running Monitor settings.. this is not detected by ZoneMinder, so a weak point!!
By running ImageMagick, you can even see if a camera is online, offline, BlueMuted or running low on InfraRed!
Just grab a frame and run this through ImageMagick on script, will do the trick!
I'm also bothered by blue screens sometime being recorded as events.
If I access the camera directly through its built in interface, the picture doesn't drop, but zoneminder will drop the picture and display the blue screen and record an event.
I've lowered the framerate in ZM but may need to do more experimenting.
Dave
Dave
