Where is the options file hidden?
c0mputerking
Post by c0mputerking »
I have set the skin to xml and get a xml page now instead tof the zm console page as i cannot get to the options page threw the web anymore is there a way to set the skin back to classic using cli? should'nt all the options settings be in a file somewhere? I dug around my systembut did not find anything.
does an options file exist? if not i can resotre from backup i suppose
bb99
Re: Where is the options file hidden?
Post by bb99 »
c0mputerking
Not helpful link to the link is broken seriously there is no config file where i can just change things back using cli?
bb99
Post by bb99 »
Links not broken; it's the way for you to gain access to the classic menu. Type: Http://localhost/zm/index.php?skin=classic in the browser. It'll take you to the classic menu where you can make your changes in ZM.
