Trouble compiling ZM 1.25.0 on Debian 6.0.4 x64 from source
pdxkris
Postby pdxkris » Wed Apr 04, 2012 5:18 am
I have a fresh install of Debian 6.0.4 x64 that I plan on having as a dedicated ZM box. Following the wiki and a number of tutorials, I believe I have all of the pre-reqs installed, but am still having issues compiling ZM that I wasn't able to sort out by searching the forum.
Here's my ./configure settings:
./configure --prefix=/opt/zm --with-webuser=www-data --with-webgroup=www-data --enable-mmap=yes --with-webdir=/var/www --with-cgidir=/usr/lib/cgi-bin ZM_SSL_LIB=openssl ZM_DB_PASS=**** --with-webhost=kZoneMinder
I export the following:
export CFLAGS="-march=native -O2 -pipe" && \
export CXXFLAGS="${CFLAGS}" && \
export CPPFLAGS="${CFLAGS} -D__STDC_CONSTANT_MACROS"]
I'm able to fun ffmpeg successfully:
ffmpeg version 0.10.2 Copyright (c) 2000-2012 the FFmpeg developers
  built on Apr  3 2012 15:05:55 with gcc 4.4.5
  configuration: --enable-gpl --enable-shared --enable-pthreads
  libavutil      51. 35.100 / 51. 35.100
  libavcodec     53. 61.100 / 53. 61.100
  libavformat    53. 32.100 / 53. 32.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 61.100 /  2. 61.100
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0.  6.100 /  0.  6.100
  libpostproc    52.  0.100 / 52.  0.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
Here are the "no" items from when I run configure:
checking whether we are cross compiling... no
checking for gcc option to accept ISO C89... none needed
checking for _Bool... no
checking for struct sigcontext.eip... no
checking whether gcc needs -traditional... no
checking whether stat accepts an empty string... no
checking for _doprnt... no
checking for ioctlsocket... no
checking for pnmscale... no
checking for x264_predict_16x16_init in -lx264... no
checking for av_image_copy in -lavcore... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
And here's the fun part of the 'make' output (ran as root):
lcrypto -ldl -lpthread -ljpeg -lmysqlclient
zm_ffmpeg_camera.o: In function `FfmpegCamera::Capture(Image&)':
zm_ffmpeg_camera.cpp:(.text+0x6d): undefined reference to `av_free_packet'
zm_ffmpeg_camera.cpp:(.text+0xf3): undefined reference to `avcodec_decode_video2'
zm_mpeg.o: In function `VideoStream::~VideoStream()':
zm_mpeg.cpp:(.text+0x3c5): undefined reference to `avio_close'
zm_mpeg.cpp:(.text+0x485): undefined reference to `avio_close'
zm_mpeg.o: In function `VideoStream::OpenStream()':
zm_mpeg.cpp:(.text+0x5e1): undefined reference to `avio_open'
zm_mpeg.o: In function `VideoStream::SetupFormat(char const*, char const*)':
zm_mpeg.cpp:(.text+0xaf3): undefined reference to `av_guess_format'
zm_mpeg.cpp:(.text+0xbd8): undefined reference to `av_guess_format'
zm_remote_camera_rtsp.o: In function `RemoteCameraRtsp::Capture(Image&)':
zm_remote_camera_rtsp.cpp:(.text+0x1c6): undefined reference to `avcodec_decode_video2'
collect2: ld returned 1 exit status
zm_ffmpeg_camera.cpp:(.text+0x6d): undefined referencemake[2]:  to *** [zmf] Error 1`
av_free_packet'
zm_ffmpeg_camera.cpp:(.text+0xf3): undefined make[2]: reference*** Waiting for unfinished jobs....
make[2]: *** [zma] Error 1
make[2]: *** [zmc] Error 1
make[2]: *** [zmu] Error 1
make[2]: *** [zms] Error 1
make[2]: Leaving directory `/home/zoneuser/Downloads/ZoneMinder-1.25.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/zoneuser/Downloads/ZoneMinder-1.25.0'
make: *** [all] Error 2
I've tried a couple of different builds of ffmpeg (from source and apt), as well as ZM 1.25.0 and 1.24.4 but always get the same results. Can anybody suggest a direction to troubleshoot in? I'm technically savvy, but compiler issues aren't my strong point. Thanks!
knnniggett
Re: Trouble compiling ZM 1.25.0 on Debian 6.0.4 x64 from sou
Postby knnniggett » Thu Apr 05, 2012 5:28 pm
I'm not running Debian. However, I thought I'd throw a couple of suggestions since no one else has stepped in:
  • When you built ffmpeg, did you run "make install-libs" in addition to the usual "make install"?
  • Try using ffmpeg 0.6.5 from git. The latest ffmpeg causes zoneminder 1.25 to not compile properly on CentOS so perhaps the same is true for Debian.
We want... a shrubbery! [dramatic chord]
Blog in Progress. Using the ESP8266 WiFi chip as an external trigger source.
http://zmtrigger.blogspot.com/
pdxkris
Postby pdxkris » Fri Apr 06, 2012 4:17 am
Thanks for trying, but still no luck :(
I reverted to a snapshot I had taken before installing ffmpeg previously and pulled the 0.6.5 version from git, compiled it successfully (including make install-libs as I had done before). ffmpeg 0.6.5 itself seems to work, but I still get this when trying to compile ZM:
knnniggett
Postby knnniggett » Fri Apr 06, 2012 12:28 pm
Have you read these by chance?
http://www.zoneminder.com/wiki/index.php/Debian
http://www.zoneminder.com/wiki/index.php/Debian_6_Squeeze_64-bit_with_ZoneMinder_1.25.0_Preview,_FFmpeg,_libjpeg-turbo,_Webmin,_Cambozola%28Spanish_Diciembre_2011%29
According to the first link, zoneminder is in the Debian unstable repository so you may be able to cheat and just do an "apt-get install zoneminder"
The second link is in Spanish, but looking through it, the author does the following immediately after compiling ffmpeg:
cd /lib && ln -s /usr/local/lib/libswscale.so.0 && \
ln -s /usr/local/lib/libavformat.so.52 && \
ln -s /usr/local/lib/libavcodec.so.52 && \
ln -s /usr/local/lib/libavutil.so.50 && \
ln -s /usr/local/lib/libavdevice.so.52
ldconfig
hope that helps.
Return to “ZoneMinder 1.25.x”
