320x240 resolution only with ZM and Foscam F18918W? ZM lock?
bjorn
Post by bjorn »
Hi all! :)
Beside the bug http://www.zoneminder.com/forums/viewto ... 5&start=15 I also have a resolution problem with ZM and the Foscam F18918W ipcam.
I cannot get it to work above the 320x240 resolution, in Zoneminder.
Via the webbrowser the 640x480 resolution works normally, when I login to the cam. But when I try to get the stream into a 640x240 mode into Zoneminder it fails.
Anybody experience the same issue or knows a workaround maybe? Are there config files locking the screen resolutions in Zoneminder?
I followed this wiki http://www.zoneminder.com/wiki/index.php/Foscam_FI8918W and this says that Zoneminder can handle the 640x480, but I doubt it after two days of google and playing with the settings.
Any help would be much appreciated!
:D
PacoLM
Re: 320x240 resolution only with ZM and Foscam F18918W? ZM l
Post by PacoLM »
Post logs of /var/log/syslog and check your shared memory settings, maybe are enough to support 320x240, but not enough to support twice the resolution.
bjorn
Post by bjorn »
Thanks for looking in to this, my knowlegde is to short to sort it out. I can see at the end of the log that there is a problem with the shared mem. Hope that you can shout something what I can do to fix it. Thanks in advance!! :)
/var/log/syslog
ar 15 22:59:48 toshiba-debian zmc_m13[2600]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd9]
Mar 15 22:59:48 toshiba-debian zmc_m13[2600]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd9]
Mar 15 22:59:49 toshiba-debian zmwatch[2317]: ERR [Can't get shared memory id '7a6d000e', 14: No such file or directory]
PacoLM
Post by PacoLM »
http://www.zoneminder.com/forums/viewto ... ory#p72552
Hope it helps, credits to Pada, author of the original script,
PacoLM
bjorn
Post by bjorn »
Thanks Paco for the effort!
I will run the script later on and will update if it was succesfull.
dma_k
Post by dma_k »
I've got the same problem with Foscam FI8918W (firmware v11.37.2.48, Web UI v2.4.10.2, Zoneminder v1.25.0, libjpeg-8d-1).
Would be it possible to shift the loglevel from WARN to TRACE for this event (bit of lazy to recompile Zoneminder myself)?
