Can´t stream from monitors.
sgn
Post by sgn »
I´m running 1.24.4 on Debian 6.0.4 with a D-Link DCS 2130. I´ve set up the monitor, and I can review "stills" of events, but can´t stream recorded or live images with Firefox (I get just a white screen and the fps indicator does´t show anything). I didn´t try IEX with cambozola. Capture resolution is 1280x800@4fps, hardware is Core i5@3Ghz, 4GB RAM, 6TB software RAID storage. I compiled zm with "--enable-mmap=yes" so as to avoid shmem issues. Setting a lower resolution tends to "red out" the input in ZoneMinders console.
sgn
Re: Can´t stream from monitors.
Post by sgn »
Turned out to be cgi-bin permissions preventing zms from running :)
