Hi everybody.
I want to know What videos encoder, audios encoder that zoneminder support?
and where can I find its documents?
Thank so much!
Re: What videos encoder, audios encoder that zoneminder supp
Can you help me?
Thanks!
Thanks!
No audio encoder.
Default video is mjpeg stream, though if you build in ffmpeg it can stream mpeg container. Other codecs can be be used if you compile them in and add any needed bits of code in.
Audio is not supported.
