Good afternoon.
I've a problem with configuration of ZM 1.25 and eyeZM 1.3.
ffmpeg everything looks like good, ZM 1.25 working as expected as well, but I can't see live feed from iPhone.
I see thumb image but all times get timeout and stream is not showing on the device.
Can somebody give an idea how to fix it please?
(Ubuntu 11.10, ffmpeg latest from svn with h264, zm 1.25 + eyeZM from ZM package, eyeZM 1.3 client on iPhone)
Thanks.
ZoneMinder 1.25 & eyeZM 1.3
Re: ZoneMinder 1.25 & eyeZM 1.3
I discussed with someone having a similar issue. First thing is, ZoneMinder 1.25.x includes eYe zm but not httpsegmenter. You have to donwload the p2fs3 version from http://eyezm.com/files.php and only compile compile and install the httpsegmenter from the downloaded archive. This solved the issue and hopefully it does for you.
Hope this helps
Hope this helps
It was a first issue also there was some issue with exec (shellexec) command to start httpsegmenter, zmstreamer and ffmpeg work together and and start streaming.monex wrote:Hi,
Hope this helps
All issues were fixed as I told.
Anyway, thx for the help.
Users browsing this forum: No registered users and 6 guests
