Time to next event = 1 seconds
mrd
Post by mrd »
What is the problem with video playback presenting the message "Time to next event = 1 seconds".
I have been seeing this on several different install of ZM on both Arch and Ubuntu. I can't seem to find any mention in the forums and certainly no resolution. I find that most of my events are not viewable due to this bug.
Thanks,
Michael
MRD
bb99
Re: Time to next event = 1 seconds
Post by bb99 »
In another post I referenced a possible solution to this about midway through the thread:
http://www.zoneminder.com/forums/viewto ... 21&t=17440
Looks to be a buffer thing (at least to the original poster).
mrd
Post by mrd »
Thanks, I'm betting that changing the buffers back will fix it since I did up them quite a bit. I'm not sure how to properly capture full videos now though...without generating multiple small events.
MRD
bb99
Post by bb99 »
Use the post event image count buffer. Set it to 10 to 15 sec (value is in frames so fps * sec.). This value is not a true buffer but a continuation number of frames to record. This will join the short segments together so long as they occur within your value. Nice buffer hints toward end of this thread: http://www.zoneminder.com/forums/viewto ... lit=buffer
