1.24.3 montage scale setting
beire
Post by beire »
I recently updated 2 systems to 1.24.3 svn and seem to be experiencing the same problem on both systems.
When i'm in montage view, the scale dropdown menu seems to have lost any function. It simply doesn't work anymore.
Is there a fix for this?
Thx.
punch-card
Post by punch-card »
I notice this when I first started using app, it does not work in Firefox, but I just tried it in IE, and it seems to work.
Probably, coding in html/php generated for browser...
Best Regards
Mike
beire
Post by beire »
punch-card wrote:I notice this when I first started using app, it does not work in Firefox, but I just tried it in IE, and it seems to work.
Unfortunately internet explorer is not an option for me since i'm running linux or mac on all machines.
No existing fix for this issue?
Pyrrhic
Post by Pyrrhic »
Alas, resize does not work in Chrome, either...and we too only run Linux (Ubuntu 10.10).
Best,
P.
zoneminder
Site Admin
Post by zoneminder »
There appears to be a javascript error being triggered in Mootools. I will take a look and see if I can figure out what is triggering it.
Phil
zoneminder
Site Admin
This should be fixed now in the SVN repo.
Phil
