ACTi has a mjpeg stream using the following format:
http://login:pwd@address:port/cgi-bin/cmd/encoder?GET_STREAM
I have it on a ACM-5611. You need to update the firmware to the latest:
Firmware Version = A1D-220-V3.12.13-AC
Here is my setup under the source tab:
Source>General
Name Monitor-10
Source Type Remote
Function Monitor
Enabled [/]
Linked Monitors
Maximum FPS 5
Alarm Maximum FPS 10
Reference Image Blend %ge 7
Triggers None available
Source>source
Remote Protocol HTTP
Remote Method Simple
Remote Host Name admin:123456@192.168.7.200
Remote Host Port 80
Remote Host Path cgi-bin/cmd/encoder?GET_STREAM
Remote Image Colors 24 bit color
Capture Width (pixels) 1280
Capture Height (pixels) 720
Preserve Aspect Ratio
Orientation Normal
Here is the settings that count in the camera
Video Settings:
Camera Name ACTi-1
Streaming Method TCP only
B2 Frame Enable [ ]
Audio In disabled
Resolution 1280x720
Frame Rate Mode Constant
Frame Rate 10
Encoder Type MJPEG
Video Quality [50] (1 ~ 100)
Video Control Port [6001 ]
Video Streaming Port [6002 ]
I use MPEG4, see my post in the hardware questions about this.
