zmMemRead()
zmMemRead()
Post by 382527398571 »
How do I check whether a signal is valid? ZoneMinder::Memory::zmMemRead($monitor, ['shared_data:signal']) always returns 1.
Signal Check Colour : #0000c0
Thanks.
Last edited by 382527398571 on Thu Sep 09, 2010 10:01 pm, edited 2 times in total.
382527398571
When TIMESTAMP_ON_CAPTURE is disabled it works.
It might be something with Monitor::CheckSignal() in src/zm_monitor.cpp.
                // Avoid sampling the rows with timestamp in
                int y = index / (width * colours);
                if ( y < label_coord.Y() || y > label_coord.Y()+Image::LINE_HEIGHT )
                    break;
382527398571
Index: src/zm_monitor.cpp
--- src/zm_monitor.cpp  (revision 3120)
+++ src/zm_monitor.cpp  (working copy)
@@ -1024,7 +1024,7 @@
                     break;
-                if ( y < label_coord.Y() || y > label_coord.Y()+Image::LINE_HEIGHT )
+                if ( y < label_coord.Y() || y <= label_coord.Y()+Image::LINE_HEIGHT )
                     break;
             const unsigned char *ptr = buffer+(index*colours);
mastertheknife
Post by mastertheknife »
I can confirm, your patch does fix the signal check. I can see now lines containing Signal Lost and Signal Acquired in my system log.
Added to here if you don't mind: http://www.zoneminder.com/wiki/index.ph ... 2_Bugfixes
mastertheknife.
zoneminder
Site Admin
Post by zoneminder »
Thanks. Now updated.
Phil
