I have just installed ZM v1.24.2 on a fresh install of Ubuntu and ZM appears to be working.
I have added the M1011-W as a remote monitor but when I open the feed or try to configure the zone there is no image stream.
Could someone provide a working configuration for a M1011-W?
AXIS M1011-W - not streaming
Re: AXIS M1011-W - not streaming
Hi!noddy wrote: Could someone provide a working configuration for a M1011-W?
Here's my configuration...
Source type: Remote
Maximum FPS: (not set)
Remote protocol: HTTP
Remote Method: Simple
Remote host: user:password@192.168.0.1
Remote host port: 80
Remote host path: /axis-cgi/mjpg/video.cgi?resolution=640x480&compression=20
Image buffer size: 20
Warmup frames: 10
Initially i didn't get any stream with 640X480 using default values for image buffer and warmup frames.
Hope this helps
- Henrik
Just get it to work like this:
Remote Protocol: http
Remote Method: simple
hostname: 192.168.0.1 (IP of your camera)
Port: 80
Host Path: / axis-cgi/mjpg/video.cgi? resolution = 320x240 & compression = 20
Color: 24 bits
Width: 320
Height: 240
Max FPS: 30.00
Alarm Max FPS: 25.00
I need to work with 640x480
Anyone?
Port: 80
Color: 24 bits
Width: 320
Height: 240
Max FPS: 30.00
Anyone?
^THIS finally got some images showing on my zoneminderhenrik wrote:Hi!noddy wrote: Could someone provide a working configuration for a M1011-W?
Source type: Remote
Warmup frames: 10
Hope this helps
- Henrik
a step forward
I have an Axis M3204 and an AXIS Q1755 and this did the trick for both.
Now, if I could only get real video out of them instead of mjpeg that would be awesome
- Contact:
Users browsing this forum: No registered users and 6 guests
