very good cam, cheap around $40 to $50, tested in ubuntu 8.04 and 9.10 with ZM 1.24.2 (and winXP with VLC)
no special setup needed - standard uvcvideo cam - here's some info from 'lucview' RE pixels and framerates
obviously framerates are what you set in the config - those numbers here are 'maximum possible' with good light
view is about 15% more than the distance (eg 10 ft distance = 11 1/2 ft wide picture)
the device ID is 046D:0807
palette can be YUVU - which seems faster than the others (more fps)
luvcview version 0.2.1
Video driver: x11
A window manager is available
video /dev/video0
/dev/video0 does not support read i/o
{ pixelformat = 'YUYV', description = 'YUV 4:2:2 (YUYV)' }
{ discrete: width = 640, height = 480 }
Time interval between frame: 1/30, 1/25, 1/20, 1/15, 1/10, 1/5,
{ discrete: width = 160, height = 120 }
{ discrete: width = 176, height = 144 }
{ discrete: width = 320, height = 240 }
{ discrete: width = 352, height = 288 }
{ discrete: width = 640, height = 360 }
{ discrete: width = 640, height = 400 }
{ discrete: width = 800, height = 600 }
Time interval between frame: 1/15, 1/10, 1/5,
{ discrete: width = 960, height = 720 }
Time interval between frame: 1/10, 1/5,
{ discrete: width = 1280, height = 720 }
{ discrete: width = 1280, height = 800 }
{ discrete: width = 1280, height = 1024 }
Time interval between frame: 2/15, 1/5,
{ pixelformat = 'MJPG', description = 'MJPEG' }
Video driver: x11
video /dev/video0
Available controls of device 'Camera 1' (Type 1=Integer 2=Boolean 3=Menu 4=Button)
V4L2_CID_BASE (predefined controls):
index:9963776 name:Brightness type:1 min:0 max:255 step:1 def:128 now:128
index:9963777 name:Contrast type:1 min:0 max:255 step:1 def:32 now:32
index:9963778 name:Saturation type:1 min:0 max:255 step:1 def:31 now:31
index:9963795 name:Gain type:1 min:0 max:255 step:1 def:0 now:0
V4L2_CID_PRIVATE_BASE (driver specific controls):
index:134217728 name:Backlight Compensation type:1 min:0 max:1 step:1 def:1 now:1
index:134217729 name:Power Line Frequency type:3 min:0 max:2 step:1 def:2 now:0
Menu items:
index:0 name:Disabled
index:1 name:50 Hz
index:2 name:60 Hz
index:134217730 name:Sharpness type:1 min:0 max:255 step:1 def:130 now:130
