zoneminder build with apache-mpm-worker?
durtball
Post by durtball »
i bottleneck when running apache prefork can i build with apache worker and run ZM? how do i do it?
MarcoP
Post by MarcoP »
PHP it's not a multithreading language.
Tuning up the prefork is the way to go.
durtball
prefork
Post by durtball »
what do u suggest?? i have a 1.6 pentium with 512 of ram that im wanting to use as a security dvr. if i load prefork it maxes out everything..
MarcoP
Post by MarcoP »
Think ZM as a streaming-recording-processing server. Not an easy task.
It all depends on how many cameras you use and how serious you are about having a security system.
Option 1
However lowering the monitor size, streaming and recording fps while creating zones for each monitor is a good start.
Option 2
If you have time to spend you can try to install a worker apache with fastcgi and then you can start playing with loading\unloading php modules till you get it stable.
Not all php modules have issues ;) and fastcgi assure you that anything happen in that thread remain isolated.
It uses less memory (shared or not) and it's a bit slower.
It takes time and patience.
Last but not least option, grab the hardware able to handle your "unspecified" number of cameras.
