Shell Script: creating one video file per day
beerygaz
Post by beerygaz » Mon Mar 01, 2010 7:43 am
My events structure doesn't look like yours suggests.
I have ./events/<monitorID>/<5> like this:
/var/lib/zoneminder/events/19/89799
ls -la in Monitor ID 19 folder reveals:
drwxr-xr-x    2 apache apache 12288 2010-02-28 10:23 89786
drwxr-xr-x    2 apache apache 20480 2010-02-28 11:02 89789
drwxr-xr-x    2 apache apache 12288 2010-02-28 11:55 89790
drwxr-xr-x    2 apache apache 12288 2010-02-28 12:59 89793
drwxr-xr-x    2 apache apache 12288 2010-02-28 13:02 89795
drwxr-xr-x    2 apache apache  4096 2010-02-28 17:54 89797
drwxr-xr-x    2 apache apache 20480 2010-03-01 06:11 89799
Any idea why my events folders are these numbers and not named by date?
Version: ZM 1.24.1
Flav
Post by Flav » Mon Mar 01, 2010 12:17 pm
beerygaz wrote:My events structure doesn't look like yours suggests.
Version: ZM 1.24.1
This is the good structure the script find the events Creat at this Date
whatboy
Post by whatboy » Mon Mar 01, 2010 5:44 pm
You're not using Options -> Paths -> USE_DEEP_STORAGE on to store events...
beerygaz
Post by beerygaz » Tue Mar 02, 2010 10:17 am
Flav / whatboy - seem to be conflicting answers. Do I keep the existing structure and look for some other problem? Or do I need to enable USE_DEEP_STORAGE?
Flav
Post by Flav » Tue Mar 02, 2010 12:18 pm
i'm not use : USE_DEEP_STORAGE and it's work.
coke
Post by coke » Tue Mar 02, 2010 8:47 pm
Deep storage also increases the speed of deletes, eliminates possible file limit problems down the road, and probably a few other things that are handy.
whatboy
Post by whatboy » Tue Mar 02, 2010 10:06 pm
I only have a problem, I created a script with my solution, to added to the crontab... script (zmmkmov) looks like...
#!/bin/sh
rm /home/user/bin/list.txt
ls -Ca --format=single-column /events/1/$(TZ=EST24EDT date +%y/%m/%d)/.*/*capture.jpg > /home/user/bin/list.txt
/usr/bin/mencoder "mf://@list.txt" -mf fps=5 -o /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi -ovc lavc -lavcopts vcodec=mpeg4
sudo mv /home/user/bin/mon1-$(TZ=EST26EDT date +%F).avi /stuffs/video
and on crontab I set to ran at 00:10 each day, but emncoder exit with error, I don't have the e-mail that shows the error, but I'll post it here later, and I can't use SUDO on a crontab??? gives me an error too
SHELL=/bin/sh
HOME=/home/user
PATH=/usr/bin:/bin:/home/user/bin
LOGNAME=user
USER=user
10 00 * * * umask 002; /home/user/bin/zmmkmov
Maybe is the "mf://@list.txt" I'll try with "mf://@/home/user/bin/list.txt" and see if mencoder doesnt fail, but sudo??? why can I use sudo on a crontab??? it says I can only use sudo on a tty console...
But if I ran it manual from console, nor mencoder, nor sudo (ofcourse) gives me errors!!!
kongobongo
Post by kongobongo » Mon Apr 19, 2010 6:49 pm
I've created the script from the first post and customised it with the correct options, when I run it I get the following output....
Found ZM Events Directory: /var/www/zm/events/ -> OK!
Found Video Output Directory: /var/www -> OK!
Found Monitor: 10 -> OK!
Found requested day: 2010-04-19 -> OK!
Found FFmpeg binary: /usr/local/bin/ffmpeg -> OK!
Processing wanted events......23431 events found
Building video: /var/www/2010-04-19--Monitor-10.avi -> FINISHED!
Removing temporary files, bye!
The amount of events is incorrect, I only have a total of 1375 events combined for both cameras. The output video file is only 1mb in size.
Any suggestions as to where I am going wrong?
brunitho
Post by brunitho » Wed Apr 28, 2010 8:09 pm
I'm having problems with the line 73 states:
argument list too long
has some way to improve this line or reduce the amount of arguments?
kongobongo
Post by kongobongo » Wed Apr 28, 2010 8:20 pm
Yep, i'm getting that argument error as well now.....
The script looks like a good starting point, just needs looking at. I've tried to get in touch with Trendkill via email and msn but with no joy :(
johnnytolengo
crontab
Post by johnnytolengo » Wed Apr 28, 2010 8:30 pm
whatboy be careful with the crontab expressions, try with this:
as a root
10 0 * * * root /home/user/bin/zmmkmov
as apache
10 0 * * * www-data /home/user/bin/zmmkmov
good luck.
Tolengo.
brunitho
Post by brunitho » Wed Apr 28, 2010 8:31 pm
what a pity
my zoneminder is not willing to export the videos is still saying, exporting and not displayed the files to download.
look
http://www.zoneminder.com/forums/viewto ... highlight=
and my HD is getting full.
kongobongo
Post by kongobongo » Sat May 01, 2010 7:34 am
I am speaking to TrendKill, the original author about the problems so I will post an update as soon as I have one
lifeisboost
Post by lifeisboost » Mon May 24, 2010 8:31 am
Hello everyone.
I am trying to use this script but it never finds my events. i manually tried running the command
[root@localhost zm]# ls -Al /var/www/html/zm/events/1/ --time-style=long-iso |grep -l 2010-05-01
to try and find the events but this is the response it returns. im not sure where to go as i have not found any answers in looking through the net on the response.
(standard input)
Users browsing this forum: No registered users and 11 guests
