UK Car Registrations
wirefly
Post by wirefly »
I've been using Zoneminder for a long time now, what is the best way to get my modifications into zoneminder?
The largest modification I have to the code is to scan the image for a UK registration plate from a vehicle, this is then stored with the alarm event. I have spent several months perfecting this now and I feel its ready for you all to play with.
How should I pack my modifications for you people to use?
Flav
Post by Flav »
very good job
May be a zip files and a Wiki documentation
cordel
Post by cordel »
Patch form is usually the best. Just in case Phil wants to add it to the trunk.
coke
Post by coke »
While you're at it, are UK and US plates different enough (hell, ours change by state or what baseball team you like) that it'll only work on UK plates?
That'd be a great mod if it works, especially since I just installed cameras on all of our garage doors.
wirefly
Post by wirefly »
I've no vehicles outside of the UK to test with :) Although a donation of a 1959 cadillac wouldn't go amiss :lol:
Its used now to "clock in" and "clock out" vehicles at a gatehouse.
cordel
Post by cordel »
What OCR did you use or is this something completely custom?
If it's OCR based, mostly you just have to match the fonts correct?
johnnytolengo
share
Post by johnnytolengo »
Can you share the script with us?
Thanks.
JT.
wirefly
Post by wirefly »
I'm preparing to make a diff and create a package which can be applied and putting some documentation together on my wiki.
Will be up and ready by the weekend!
Thanks!
kingofkya
Post by kingofkya »
wow this will be great thanks for the effort.
coke
Post by coke »
Ditto on the kudos, can't wait to see if I can tweak it to do US plates.
kp4djt
Post by kp4djt »
What is the status on this? I am getting a lot of request for capturing plates, I would like to setup something and be able to show it. My other option is a very fast megapixel cam with IR flash to get good images of plates.
Chuck Hast -- KP4DJT --
Web site www.wchast.com
ZM demo www.wchast.com/zm
kingofkya
Post by kingofkya »
I sent him a pm earlier he just busy and hasen't had time.
kp4djt
Post by kp4djt »
I wonder how this will work with US plates, some of them like the ones we have here in FL have something right in the middle of the plate, so it makes for interesting viewing, I have got to see if the plate can be illuminated such that only the tag number is visible, if not the big orange in the middle of a FL plate is a PITA. [/img]
kingofkya
Post by kingofkya »
The bigest thing thats gona stop it for working is uk plates are made to work with this kinda of stuff. US plates are not
kp4djt
Post by kp4djt »
Yes. I just set up a plate and illuminated it with IR, lost all of the lettering, so that means that the tag is set up as a big reflector for LIDAR... there has to be some wave length that will give me a good reading, they are installing tag readers on the turnpikes around here.
