Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
quietas
Post by quietas » Tue Oct 06, 2009 11:27 pm
I've got yet another question. I know, I'm a pain in the ass.
Is it possible to to make a version of this which is portable. Some how self contained in one folder or at least has a settings file which can be moved to multiple computers?
kaneco
ZM4MS and windows home server
Post by kaneco » Wed Nov 11, 2009 5:59 pm
I have a lot of questions to do about this application on windows home server
1- Has anyone tried to install the "launch applications" add-on for windows home server to launch the ZM4MS application?
2- Anyone know a a better solution to do this??
3- There are any application on development to install ZM4MS like a add-on on windows home server console
Best regards
znelbok
Post by znelbok » Fri Nov 27, 2009 4:32 am
Hi guys
where do I find a link to download this but of software?
There is nothing in the first post of this thread and I cant find it on the downloads page either
Mick
quietas
Post by quietas » Fri Nov 27, 2009 4:43 pm
trendkill
Post by trendkill » Wed Dec 02, 2009 3:10 pm
I tried it, but it asks only username and password...
where can I set the server IP address and others?
Thanks,
Gabor
quietas
Post by quietas » Wed Dec 02, 2009 4:13 pm
trendkill wrote:I tried it, but it asks only username and password...
Thanks,
Gabor
Unfortunately his documentation is lacking completely, but if you look back just one page of comments, you will see that the login user/pass are both admin. Also on that same page I had detailed how to do the basic setup for another user as well.
trendkill
Post by trendkill » Thu Dec 03, 2009 8:30 pm
Ohh, thanks! :)
Thanks,
Gabor
VF
Configuration problems
Post by VF » Mon Dec 14, 2009 11:32 am
Hi Everybody,
I'm trying to configure a Viseon Viewer to look some monitors running on a remote ZM machine (with IPV6 public address).
I'm reaching the machine via browser with this info:
http://[2001:5c0:xxxx:xxxx::xxxx]/zm/index.php
monitor1: 192.168.1.10 PORT 200
monitor2: 192.168.1.12 PORT 201
zm access1: admin admin
zm user1: root root
Im' not able to configure the viewer. It doesn't work. My questions are:
1)where I can put my ZM ip address?
2) someone could give me some info about a complete working configuration for remote zm?
Thanks a lot.
regards.
jameswilson
Post by jameswilson » Fri Feb 12, 2010 7:07 pm
Ive never tried ipv6 addressing but it should work in url mode as a minimum.
Im currently working on V3 zm4ms, and this will have better framerate, and if i can get it self healing flash/mpeg streaming.
Over the next couple of weeks i will release a public alpha of a pure low bandwidth viewer. If this goes well i will merge this into zm4ms. I need to update it due to the way we use it to support more than 36 cams, so now would be a good time for suggestions. No promises but if they have general use i will try to include them.
James Wilson
quietas
Post by quietas » Fri Mar 12, 2010 7:26 pm
Great, I see you are working on a new version. How is it coming and do you need any input or assistance testing?
A low bandwidth version would be great.
Also a way to integrate multiple ZM installations easily with multiple cycled views. This may be too much, but I have 4 installations with a total of 50 cameras and a way yo view all of them at once would be useful.
A config file or some way to export settings would be great as well. An easy way to set it up once and then move between computers or users.
jameswilson
Post by jameswilson » Mon Mar 15, 2010 3:26 pm
I am working on a new version but i wouldnt hold your breath yet lol
Its pretty much a complete rewrite. I think a settingsa file would be a good idea, but due to the number of settings stored it might be too mcuh work. Ill see. i might chnage the way settings are stored to make it easier.
James Wilson
quietas
Post by quietas » Mon Mar 15, 2010 3:49 pm
Possibly an export to an xml file and import option? With 4 sites and nearly 50 cameras, a way to save my config would be useful.
jameswilson
Post by jameswilson » Mon Mar 15, 2010 3:51 pm
that might be an option as i xml to store the settings.
Ill have a look
James Wilson
johndpar
"pop up alarm" and "home automation"
Post by johndpar » Thu Mar 25, 2010 12:52 am
Hi James
Great piece of work the viewer is!
Trying to figure out if the pop up alarms work.
My system running 1.24.2 has external triggers that fire and work just fine within zm. The page that the alarm settings point to returns a table and if a trigger is active the "State" is 2 and the "Trgstate" is 1.
Alarm Mode Enabled is ticked in zm4ms.
Nothing seems to happen when a trigger happens.
(EDIT: figured out I had to set up map view first - done that and now get AlarmiNFO dialog but looks like parsing of status page is broken - in Diag tab first line is 192.168.x.x "t" "" "able", then 13th line has "</" in Mon and "v" in State)
Any ideas?
Also, what is the "Home Automation" tab intended for?
Many thanks
John
sami181973
Need the download path of Windows Live viewer
Post by sami181973 » Tue May 04, 2010 2:41 am
1. Need the down-loadable path of Windows Live viewer
2. Please let me know the stable version
3. H264 codec support including RTSP
4. Does this support any third party cameras for viewing on PC?
