using PSTN without internet/lan connection??
dwiest
Post by dwiest »
are we can use zoneminder on regular telephone line (PSTN) without internet/lan connection?
timcraig
Post by timcraig »
It's possible to set up a PC with a phone line modem as a PPP dial-up server that connects you to the local network you're Zoneminder box is on.
You can do a search on dial-up ppp server how to's.
The slow speed of dial-up is going to be a big obstical to using Zoneminder. You'll need to set the image scale and frame rates really low.
kingofkya
Post by kingofkya »
dont forget theres also the cell phone tethering which could be a little FASTER
curtishall
Post by curtishall »
kingofkya wrote:dont forget theres also the cell phone tethering which could be a little FASTER
If you do this you would need to change the default port (80). Most carriers block port 80.
Also remember data usage plans...MJPEG eats alot of bandwidth
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
