I've got 2 axis cameras, axis207 and axis221. this is my problem:
for axis207 I use:
/axis-cgi/mjpg/video.cgi and everything works well
If I use this setting for axis221, there is always a delay of 7-10 seconds compared to the axis live view.
Instead if I use /axis-cgi/jpg/image.cgi it seams to work, not fluent, but works.
the problem is that the motion detection doesn't record nothing, I thing this is due to this setting.
Can you confirm? Any suggestion?
Axis 221 problem with /axis-cgi/mjpg/video.cgi
221
The source I use on my 221 is
Mine is only set to 1 FPS at the moment due to needing up to a 2 second exposure in it's current very dark location. On the positive side, with the long exposure, my 221 can see better there than I can in person.
My 207's use exactly the same source settings, and I think there's not even a 1/10th second delay. I haven't really measured that, but I can tell when I'm calling the front desk about something while watching them on a camera.
My 207w's have a very slight delay, being wireless, but when I cranked up the compression, they achieved MUCH higher frame-rates than otherwise.
/axis-cgi/mjpg/video.cgi?resolution=640x480
