no bttv for Pico video capture card in Ubuntu 8.10
cyrulution
Postby cyrulution » Sun Nov 30, 2008 9:32 pm
after upgrading Ubuntu to 8.10 (Intrepid) my so named "Pico-card" (in Zoneminder-Wiki) disappeared from dmesg. There is no "bttv" at all any more. That's all about the card in dmesg:
[    0.697858] PCI: 0000:01:00.0 reg 10 32bit mmio: [de000000, deffffff]
[    0.697868] PCI: 0000:01:00.0 reg 14 32bit mmio: [d0000000, d7ffffff]
[    0.697895] PCI: 0000:01:00.0 reg 30 32bit mmio: [dfdf0000, dfdfffff]
[    2.041795] pci 0000:01:00.0: Boot video device
and lspci says:
02:0d.0 Multimedia video controller: Brooktree Corporation Bt879(??) Video Capture (rev 11)
02:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
How can I tell Unbuntu, that there is a card that used to work in Gutsy?
Serenity is not freedom from storm; it's peace within the storm
Lee Sharp
Postby Lee Sharp » Mon Dec 01, 2008 4:08 am
It is is a 4 port single chip card, try this in the options file.
options bttv gbuffers=32 card=77 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
cyrulution
Postby cyrulution » Mon Dec 01, 2008 11:06 pm
I inserted your line in a new file bttv in /etc/modprobe.d/
But still the same:
nothing about bttv in dmesg
the same two lines in lspci
the system does almost not recognize, that there is a video capture card. How can I tell the system about the card?
As far as I know is bttv contained in the 2.26-10 kernel. Or will I have to add it?
help!
Lee Sharp
Postby Lee Sharp » Tue Dec 02, 2008 8:30 pm
Boot a Gutsy Live CD and see what dmesg says... This could be a Hardy issue. (It has a lot)
cyrulution
Postby cyrulution » Tue Dec 02, 2008 10:08 pm
Lee Sharp wrote:Boot a Gutsy Live CD and see what dmesg says... This could be a Hardy issue. (It has a lot)
The system running now is Intrepid (8.10). I started a Gutsy (7.10) Live CD and it says:
[  108.398434] bttv: driver version 0.9.17 loaded
[  108.398441] bttv: using 8 buffers with 2080k (520 pages) each for capture
[  108.475751] bt878: AUDIO driver version 0.0.0 loaded
[  108.475847] bt878: Bt878 AUDIO function found (0).
[  108.475881] ACPI: PCI Interrupt 0000:02:0d.1[A] -> GSI 21 (level, low) -> IRQ 20
[  108.475892] bt878_probe: card id=[0x0], Unknown card.
[  108.475894] Exiting..
[  108.475900] ACPI: PCI interrupt for device 0000:02:0d.1 disabled
[  108.475908] bt878: probe of 0000:02:0d.1 failed with error -22
There's nothing like that in Intrepid dmesg ...
Lee Sharp
Postby Lee Sharp » Wed Dec 03, 2008 5:04 pm
Odd... Try Ubuntu forums, and launchpad to bug the non-detection. Another regression in Ubuntu. PM me if you need help with this process. In the mean time, Gutsy works! :D
ivanjones
Postby ivanjones » Sat Dec 13, 2008 12:09 pm
Lee Sharp wrote:It is is a 4 port single chip card, try this in the options file.
Lee / Anybody, I'm new to Zoneminder and Linux...where / how do i set these options?
chenko
Postby chenko » Sat Dec 13, 2008 2:21 pm
Can vary slightly.
If you have an /etc/modules.conf add it there.
If you have a /etc/modprobe.d/ folder add it to a file called bttv in that folder (file can be called what you want too...)
You might have an update-modules command to refresh them, or just restart.
cyrulution
Postby cyrulution » Sun Jan 11, 2009 11:05 am
I tried everything and I think it's not possible to get ZM running with Ubuntu 8.10 with the so named "Pico" (=cheap ebay) cards.
I will just install the three years old life CD and hope I will be able to fix all security issues since 2006.
buzz_host
Postby buzz_host » Thu Jan 15, 2009 6:40 am
Lee Sharp wrote:This could be a Hardy issue. (It has a lot)
I can't speak for Hardy, but 8.10 (Ibex) is pretty flawless for me with these cards. I have two working in one box - I've done nothing magic and I'm quite happy to output anything that would be useful to anyone.
cordel
Postby cordel » Thu Jan 15, 2009 6:50 am
Really I have no problems with hardy. I have seen a lot more with 8.10 since it's release, seems now the forum is getting flooded with 8.10 bttv issues all of a sudden.
cyrulution
Postby cyrulution » Thu Jan 15, 2009 7:03 am
I haven't found a way to tell Ubuntu Feisty about my card=77. It simply was not able to use my video capture card. Now I have found a 1.23 live CD (the links in Wiki about "live CD" lead to the download. The links in "download" have only an old 1.22 version. I think I might get used to Madriva Linux, especially as it's not so much work any more, after the system is running.
cyrulution
Postby cyrulution » Fri Jan 16, 2009 7:11 am
cordel wrote:Really I have no problems with hardy. I have seen a lot more with 8.10 since it's release, seems now the forum is getting flooded with 8.10 bttv issues all of a sudden.
Cordel, do you have the so named "Pico" card (cheap chinese ebay)? Hardy has the same new structure with modprobe as 8.10. How did you tell Hardy about card=77 ? I haven't found a way in Intrepid.
cordel
Postby cordel » Mon Jan 19, 2009 2:22 am
Both are set the same way.
Create a file in /etc/modprobe.d name it anything you want.
ie.
name a file capturecards.
vim /etc/modprobe.d/capturecards
Insert your option line.
options bttv card=77
save the file and either unload and reload bttv or reboot the system.
cyrulution
Postby cyrulution » Mon Jan 19, 2009 5:55 am
cordel wrote:Create a file in /etc/modprobe.d name it anything you want.
ie.
I tried it this way but my problem is: in dmesg there is nothing about bttv. Not before and not after the line in modprobe.d. Intrepid just seems not to recognize the ebay-card at all. In Gutsy it had not been a problem.
Return to “Hardware Queries”
