Hi All,
My Installation of Live Cd hangs at 100% wrting to /etc/fstab.
Does anyone has a solution for this??
Dave,
Holland
Live Cd Install Hangs
You could try launching a terminal (konsole) and running livecd-install from there. This will allow you to see any error messages generated. I cant remember on 1.19.1 if livecd-install is in /usr/sbin or /home/user/bin/ but you will be able to find it if you look. You must be root to run it (sudo su).
If the error messages don't make the solution clear to you, then post them here.
Best regards,
Ross
Best regards,
Ross
