I am using openSUSE 10.3, and a logitech quickcam express (usb).
I installed ZM v1.22.3-20 via YaST. I followed the instructions here:
http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE
I did add the pacman repos, and selected the mp version, though YaST said it was pulling from the liquid-co repo (which is not supposed to caontain the mp version - - but that is probably beside the point)
I ran through the setup of apache, mysql, and zm described on the page above, and all went fine. No errors.
When I go to localhost/zm, I have the interface, and is says running at the top. But when I click on the monitor I added, there is no image. (My webcam does work in kopete.)
So I began troubleshooting, and the first thing I did was this:
# rczm restart
Shutting down ZoneMinder Daemon done
Starting ZoneMinder Daemon failed
I searched the forums, and found a user request the following command and output, so here's mine:
# sh -x /etc/init.d/zm start
+ ZM_BIN=/usr/bin/zmpkg.pl
+ ZM_PATH=/srv/www/htdocs/zm
+ test -x /usr/bin/zmpkg.pl
+ . /etc/rc.status
++ LC_ALL=POSIX
++ export LC_ALL
++ test -z '' -o -z ''
+++ exec
+++ stty size
+++ read L C
+++ echo LINES=24 COLUMNS=80
++ eval LINES=24 COLUMNS=80
+++ LINES=24
+++ COLUMNS=80
++ test 24 -eq 0
++ test 80 -eq 0
++ export LINES COLUMNS
++ case ":$PATH:" in
++ test -t 1 -a xterm '!=' raw -a xterm '!=' dumb
++ stty size
+++ echo -en '\033'
++ esc=$'\E'
++ extd=''
++ warn=''
++ done=''
++ attn=''
+++ echo -en '\017'
++ norm=''
+++ echo -en '\015 '
++ stat=' '
++ rc_done=' done'
++ rc_running=' running'
++ rc_failed=' failed'
++ rc_missed=' missing'
++ rc_skipped=' skipped'
++ rc_dead=' dead'
++ rc_unused=' unused'
++ rc_unknown=' failed''
++ rc_reset=''p='
++ rc_save=''
++ rc_restor'='
++ _rc_service=/etc/init.d/zm
++ _rc_status=0
++ _rc_status_all=0
++ _rc_todo=start
++ test start = status
++ test -n start
+ rc_reset
+ _rc_status=0
+ _rc_status_all=0
+ rc_check
+ _rc_status_ret=0
+ test 0 -eq 0
+ test 0 -eq 0
+ return
+ return 0
+ case "$1" in
+ locked=0
+ test -f /srv/www/htdocs/zm/lock
+ echo -n 'Starting ZoneMinder Daemon '
Starting ZoneMinder Daemon + (( 0 != 1 ))
+ eval startproc -t 5 -f /usr/bin/zmpkg.pl start
+ rc_status -v
+ rc_check
+ _rc_status_ret=7
+ test 7 -eq 0
+ _rc_status=7
+ test 7 -eq 0
+ _rc_status_all=7
+ return
+ test 7 -gt 7
+ _rc_status_ret=7
+ case "$_rc_todo" in
+ local i
+ for i in '"$@"'
+ case "$i" in
+ local vrt=
+ local out=1
+ local opt=en
+ test -n ''
+ opt=e
+ case "$_rc_status" in
+ vrt=' failed'
+ out=2
+ echo -e '' failed
failed
+ _rc_status=0
+ return 7
+ rc_exit
+ exit 7
Thanks for your time.
