Avermedia Linux card
Rick
Post by Rick »
Just picked up an Avermedia LX5004 card. Its a 4 port card with 4 chips (unknown if they are 878's - they are covered with heatsinks) and comes with a proprietary Linux security program embedded in a custom older Redhat distro.
The card does *not* work under ZM. The livecd install locks up tight when loading the driver.
gnuorder
Post by gnuorder »
An easy way to tell what chips it's using is to type lspci as root. Just dont have the driver automatically loading. On the live CD, maybe starting with run level 2 is enough. You type knoppix 2 at the first boot prompt. It may still lock up, I haven't looked at the live CD yet and it may be set up to load the drivers at boot time.
aot2002
Post by aot2002 »
just wondering if you guys got the avermedia working or not?
jay
