Wish List
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
maxs
Wish List
Post by maxs »
Wish list:
1. Save device settings brightness etc. in db.
Device settings can currently be changed if device used by another app
or if server powered off/on. Would like settings to be restored on ZM
startup.
2. Stream a small image but save a larger event image.
Need small images for streaming over low bandwidth connection, but
would like to keep larger more detailed images for local viewing.
3. Option to keep/discard analysis images.
Analyse images are great for setting up zones and filters, but not
needed once everything is tuned.
thanks
Tom
zoneminder
Site Admin
Re: Wish List
Post by zoneminder »
Hi Tom,
1) Shouldn't be too hard to do
2) This would require a change to zms to rescale before sending. The change itself is easy, it's the additional config and web interface that takes the time. Nevertheless, a sensible suggestion.
3) When you say discard, do you mean not use at all, or delete after a certain period of time?
Cheers,
Phil,
