I tried the Wiki http://www.zoneminder.com/wiki/index.ph ... atabase.3F and a few others... 'mysqlcheck --all-databases --auto-repair' and a few reboots. No luck. Any hints?
Console
Table './zm/Events' is marked as crashed and should be repaired
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /usr/share/zoneminder/zm_html_view_console.php on line 81
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /usr/share/zoneminder/zm_html_view_console.php on line 82
Warning: array_merge() [function.array-merge]: Argument #3 is not an array in /usr/share/zoneminder/zm_html_view_console.php on line 91
Jun 19 14:34:02 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:03 neteye zmc_dvideo0[5400]: WAR [Buffer overrun at index 31, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:05 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 24, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:14 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:15 neteye zmc_dvideo0[5400]: WAR [Buffer overrun at index 31, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:17 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 24, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:26 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 12, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:27 neteye zmc_dvideo0[5400]: WAR [Buffer overrun at index 31, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:29 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 24, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:34:30 neteye zma_m5[5747]: INF [Office: 1000 - Processing at 3.37 fps]
sysop@neteye:/var/log$ tail messages
Jun 19 14:39:06 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 24, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:39:13 neteye zmc_dvideo0[5400]: WAR [Buffer overrun at index 21, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:39:14 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 11, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:39:15 neteye zmc_dvideo0[5400]: WAR [Buffer overrun at index 29, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:39:18 neteye zmc_dvideo1[5406]: WAR [Buffer overrun at index 24, slow down capture, speed up analysis or increase ring buffer size]
Jun 19 14:39:21 neteye zmdc[5378]: INF [Starting pending process, zma -m 5]
Jun 19 14:39:21 neteye zmdc[5863]: INF ['zma -m 5' started at 07/06/19 14:39:21]
Jun 19 14:39:21 neteye zmdc[5378]: INF ['zma -m 5' starting at 07/06/19 14:39:21, pid = 5863]
Jun 19 14:39:21 neteye zma_m5[5863]: INF [Debug Level = 0, Debug Log = <none>]
Jun 19 14:39:21 neteye zma_m5[5863]: INF [In mode 3/1, warming up]
