zoneminder pictures on the web
lewis
Post by lewis »
hello all,
i have my zm box working flawlessly (connected to the internet), with some ip cameras (not connected to the internet).
i want to include in a web page a clickable still image from one ip camera, and when the user clicks a popoup windows shows ths stram (1fps).
i suppose i have to do it through zm urls, but how ???
Ye-Olde's Manor - http://ye-olde.net
zoneminder
Site Admin
Post by zoneminder »
Assuming you only want to show the stream source and none of the ZM html page then you can just put a zms url like
<img src="http://<your machine>/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=100&maxfps=1" alt="Camera 1" border="0" width="352" height="288">
in there. This is jpeg format so will only work for FireFox etc. Plus of course if you have authentication on then people will have had to have already logged in.
Phil
lewis
Post by lewis »
i try this:
http://asterix.ezhellas.com/cgi-bin/nph ... 0&maxfps=1
and i get a zero sized reply.
apache logs say:
194.145.127.66 - - [27/Sep/2006:16:23:25 +0300] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=16&scale=100&maxfps=1 HTTP/1.0" 200 - "-" "Mozilla/5.0 (Windows; U; Windows NT 5.1; el; rv:1.8.0.7) Gecko/20060909 Firefox/1.5.0.7"
in /var/log/messages i cans see:
Sep 27 16:24:43 AsteriX zms[11000]: ERR [Unable to authenticate user]
is there any way to authenticate via the url ?
i cannot allow access to my zm box without authentication...
lewis
Post by lewis »
this url works, only if i authenticate first.. i get a stream in firefox..
with IE i get a slower stream..
http://asterix.ezhellas.com/zm/zm.php?v ... 0&control=
is there any way to avoid authentication, or to pass authentication to the url ?
jameswilson
Post by jameswilson »
add
&user=<username>&pass=<Password>
James Wilson
lewis
Post by lewis »
jameswilson wrote:add
i created a web page which contains:
<img src="http://10.122.2.134/cgi-bin/nph-zms?mode=jpeg&monitor=16&scale=100&maxfps=1&user=guest&pass=guest alt="Camera 1 border="0" width="320" height="240">
<img src="http://10.122.2.134/zm/zm.php?view=watchfeed&mode=&mid=16&scale=100&control=&user=guest&pass=guest alt="Camera 1 border="0" width="320" height="240">
neither of them shows anything...
cordel
Post by cordel »
Are you creating a page viewable only on your internal network?
If not then you need your image source to be from your public domain.
Also consider that unless your using a browser that supports mjpeg, you have to use stills.
Regards,
Corey
http://asterix.ezhellas.com/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=100&maxfps=1&user=guest&password=guest
lewis
Post by lewis »
i finally did it...
you can see the still images in front page at http://twmn.net
when you click the images, you can see the live stream..
camera is in place A.
Zoneminder is in place B.
Internet gateway is in place C.
all these places (A,B,C) are connected via our wireless network.
Place C, does nat to place B.
..and it Works ;)
Zoneminder rulezzzzzz...
:lol: :lol: :lol: :lol:
jameswilson
Lewis, i have looked at your page in firefox, ie moans about language or something, but when i check path it states they are static images ie jpg1 etc, can you explain what you did?
James Wilson
lewis
Post by lewis »
jameswilson wrote:Lewis, i have looked at your page in firefox, ie moans about language or something, but when i check path it states they are static images ie jpg1 etc, can you explain what you did?
i run a cron job which gets the still images from the cameras every minute..
then, i use them as thumbnails for the links of the stream..
i live in a city with 1.2 mil people, we have a wireless network of 90 Access points, all connected between them, with multiple links.
so i have the ability to use a camera from an access point client, which is 10 miles away, without bandwidth problems..
a map of our network can be found here:
http://wind.twmn.net/index.php?page=nodes
blue dots are clients, red are the non-connected but interested..
i know, it seems greek to you ;)
jameswilson
impressive
James Wilson
lewis
Post by lewis »
jameswilson wrote:impressive
one of the landmarks in Thessaloniki, is an old vyzantine tower, which was used as a prison called the White Tower (probably it was white 1000 years ago..)
i added a camera which shows this tower in our web page (http://twmn.net)..
all 3 cameras are intellinet, in monitor mode, and the load is 0.35-0.45
