Hey All,
Found a small problem, but then came up with a workaround for building zoneminder on CentOS 4.3 x86_64. The configure works fine, make fails with errors like:
zm_signal.cpp: In function `void zm_die_handler(int, sigcontext)':
zm_signal.cpp:89: error: 'struct sigcontext' has no member named 'eip'
zm_signal.cpp:93: error: 'struct sigcontext' has no member named 'eip'
make[2]: *** [zm_signal.o] Error 1
make[2]: Leaving directory `/usr/src/builds/zm-rhel43-x86_64/ZoneMinder-1.22.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/builds/zm-rhel43-x86_64/ZoneMinder-1.22.1'
make: *** [all] Error 2
I found that if you just add --disable-crashtrace to your configure line the build works just fine. I will be posting a detailed HOWTO for CentOS 4.3 x86_64.
Mike
1.22.1 make fails on CentOS 4.3 x86_64 - workaround
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
