github permission to ZoneMinder/zoneminder.git denied
d4v1d
Post by d4v1d »
I'm trying to create a pull request for issue https://github.com/ZoneMinder/zoneminder/issues/3764 #3764.
I checkout out a new feature branch, but when I try to push the branch, I get the following error:
ERROR: Permission to ZoneMinder/zoneminder.git denied to d-bum.
fatal: Konnte nicht vom Remote-Repository lesen.
Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen
und das Repository existiert.
Is there something I am missing?
Thanks.
Edit:
I managed to create a PR across a fork.
Whiond
Re: github permission to ZoneMinder/zoneminder.git denied
Post by Whiond »
I'm having the same isue trying to creat a pull request for a repo that I don't have direct push permissions to. Can you elaborate on what you did to "create a PR across a fork"? Specifically, did you fork the original repo, push to your personal repo, and create a PR from there, or are there other steps I should be aware ofbasket random? Thanks in advence!
