Zoneminder 1.36.33 on Ubuntu 24.04.1 LTS with Php 8.3
stealthylabs
Post by stealthylabs »
Hello Zoneminder community
I have installed Zoneminder on a dedicated amd64 computer with Ubuntu 24.04.1 LTS installed. Zoneminder 1.36.33 was available as a package from the OS repositories so I installed that, since the PPA did not support Ubuntu 24.04.
Everything went smoothly, I was able to add 3 cameras and watch and record in realtime for 24 hours.
However, while setting up zmNinja on iOS I saw that the API was not working. I have setup all the required flags and the hash keys for the API to work, have custom users, and all of them have the API enabled. I also have run `chmod` on `/usr/share/zoneminder/www` for `www-data` user.
But even without zmNinja, I run `curl -k http://localhost/zm/api/host/getVersion.json` with or without authentication, and it returns a 404 saying the `/zm/api` route is not found.
The apache2 config has not been messed with and is default as in the package.
Edit: I get
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
<hr>
<address>Apache/2.4.58 (Ubuntu) Server at localhost Port 80</address>
</body></html>
How else can I debug ? i tried disabling authentication to see but same issue. Looks like the `/zm/api` route is returning errors.
Please advise.
burger
Re: Zoneminder 1.36.33 on Ubuntu 24.04.1 LTS with Php 8.3
Post by burger »
Sounds like viewtopic.php?p=135210
Post your apache config.
fastest way to test streams:
stealthylabs
That's amazing.
I was using the default zoneminder.conf which looked like below:
    AllowOverride All
    Require all granted
</Directory>
    Alias /zm/cache "/var/cache/zoneminder"
    <Directory "/var/cache/zoneminder">
        AllowOverride None
        <IfModule mod_authz_core.c>
           # Apache 2.4
           Require all granted
        </IfModule>
    </Directory>
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
</Directory>
    AllowOverride All
</Directory>
I replaced the last 3 lines with the below from https://wiki.zoneminder.com/API#Example ... inder.conf and it started working:
   RewriteEngine on
   RewriteBase /zm/api
</Directory>
   RewriteEngine on
   RewriteRule ^$ webroot/ [L]
   RewriteBase /zm/api
</Directory>
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /zm/api
</Directory>
Appreciate the help. Thank you.
