I've read the part of the faq on memory calculation. And in default settings, no analysis, (mocord setting with no frames stored, pass through storage, 3 buffers). The way I read it, it seems to say one 4K 32bit camera requires
(in bytes)
Resolution times color space
3840*2160*4 = 33.2MB
(times 3 buffers, times 1.2 overhead, times 2 for good measure)
33.2*3*1.2*2 = 240MB
One of my 9 monitors is only 5mp,but let's assume it is 4k too to simplify and it seems I need 2.2GB of RAM (no analysis, just camera pass through, h265 @10fps 1s key frames saving at ~250kB/s and playback).
This is most definitely not the case. My ZM consumes ~19GB of the 32GB total (sql uses around 1GB). It was eating all of it when I had streams at 15fps at 80 key frame interval.
I read somewhere, ZM also caches as many frames in a stream as there are between key frames. Is that true? It seems plausible. If I multiply that ram by 10 frames (as I now set my cameras to output key frames every 10 frames) this shows about 21GB I'm actually seeing.
So if the above is correct I have some way to estimate RAM required for pass through recording and playback.
Then, enters analysis. The wiki says, just multiply it by the nuber of buffers, but what about that keyframe overhead?
Let's say I want to use secondary streams of my cameras (running at only 720p) for motion detect (and more advanced ai detection). Do I have to multiply my ram required by the keyframe interval?
My server has 32gb now, I'm getting 64gb extra. I'd love to be able to predict how much of it I might need. Also, is there any benefit setting secondary streams to h264?
Up to date RAM requirement calculation.
Re: Up to date RAM requirement calculation.
Predicting memory usage is beyond me. What I do not understand is why some systems use huge amounts of RAM and mine does not.
I have 9 cameras, from 2mp to 8mp. I am doing modect on 6 hi-res streams and I am recording 6 low-res streams. 3 cameras (6 streams) have not been deployed and are currently in monitor mode. I have 7GB of RAM available and only 16GB installed.
My frame rates vary but are 5FPS to 10FPS. Keyframes are the lowest setting, which is 1 per second.
I am guessing my DB is of moderate size with 126k events stored.
If there is a formula that should work, I can test against my varied collection of cameras.
free -m
total used free shared buff/cache available
Mem: 15897 7310 319 481 8266 7767
Swap: 4095 1966 2129
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
We definitely do see some weird behaviours, but it almost always is because something can't keep up and people ignore their logs which are screaming full of warnings and errors.
