Reinstall Zoneminder
Today my PC crashed, and I installed Linux (ubuntu 22.04) again.
Zoneminder was installed on this PC and I want to put it back on.
Now I'm running into the problem that this doesn't work.
I've been working all day and have tried different ways to get zoneminder on.
How to get zoneminder on Ubuntu 22.04
And how do I remove zoneminder properly before reinstalling it?
hopefully somebody can help me.
Re: Reinstall Zoneminder
You don't say how you reinstalled Ubuntu, but unless you did it other than the usual, you'll need to reinstall LAMP and then ZM.
I first reinstalled Linux (ubuntu 22.04) on the PC, and then tried to put zm on it.
I first did this via the explanation on the zm site.
This didn't work for me.
Then I started looking for alternatives. I came across several ideas, but this didn't work either.
Can't get in touch via localhost/zm.
I see that I must first install LAMP and then ZM
What is LAMP ???
Greetings from Holland
What is LAMP ???
https://linuxconfig.org/lamp-server-set ... erus-linux
L A M P = Linux (O/S), Apache (Web Server), MySQL (database), PHP programming language.
You've already got the "L" in the forum of Ubuntu
Here is a video.
https://www.youtube.com/watch?v=lnXGau6kwGo&t=9s
Find more videos at
https://www.youtube.com/channel/UCDKfmv ... 6rO2aj5Wlg
Find more videos at
I tried these 2 videos but got an error
Error:15 https://ppa.launchpadcontent.net/iconno ... .34/ubuntu jammy Release
404 Not Found [IP: 2620:2d:4000:1::81 443]
1.34 has not been supported for years. Use 1.36.
Sorry, but I really can't figure out how to install zoneminder.
This site https://blog.programster.org/ubuntu-22- ... zoneminder doesn't work either.
Same error message here too.
I have a Foscam camera, and the Foscam software only runs on Windows.
That's why I run Zoneminder.
It run well until the PC stopped working.
Could it be that zm doesn't work with Ubuntu 22.04??
What now ??
Or another camera software??
What now ??
Ubuntu 22.04 and zm 1.36.34 run fine together.
Here's a good guide to do LAMP:
https://phoenixnap.com/kb/how-to-install-lamp-in-ubuntu
Once that's done, do: ( Don't worry about the boldface warning at the top, you'll be getting 1.34.36. )
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
And zm should fly...
Thanks, it worked.
Added the camera and it works again.
Thanks again for the help
Re: Reinstall Zoneminder SOLVED
You're welcome.
