Upgrade from ZM 1.36 to 1.37
Hello, I‘m wondering what’s the best way and procedure in upgrading my existent ZM 1.36 installation to 1.37 ? Thanks a lot for your support.
Re: Upgrade from ZM 1.36 to 1.37
On Ubuntu:
sudo apt remove zoneminder
(change or add the 1.37 repo)
sudo apt install zoneminder
Can you guide me to the 1.37 repo? Cannot find it. Thanks.
sudo add-apt-repository ppa:iconnor/zoneminder-master
No need to remove it first. Make sure you take a db backup first.
I have tried it also and got this:
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 95, in <module>
sp = SoftwareProperties(options=options)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
self.reload_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 91, in get_sources
raise NoDistroTemplateException(
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Raspbian/bullseye
any ideas? Thanks in advance
You are not on ubuntu, so don't use our ubuntu instructions.
Go to https://zmrepo.zoneminder.com and read the instructions there.
of course, I didn't look hard enough. Sorry
Thank you very much
Best regards Heimo
Thank you very much
Best regards Heimo
Thanks a lot, upgrade done. As camera setting is different compared to 1.36, is there a detailed description on the new function concept? In 1.36 I had my camera setup with modect and nodect and linked monitors respectively. In 1.37 I‘m not completely sure about the correct setup based on the new function concept. So some help would be very much appreciated.
It's worth exploring.
There are explanations of most of the new stuff, and if you upgraded (from 1.36) I think the majority of the settings get translated to the new.
Happy to explore it But I‘m wondering what‘s the correct setup in 1.37 for the following:dougmccrary wrote: ↑Wed Aug 09, 2023 8:47 am It's worth exploring.
Monitor 1: Motion detection (sub-stream) in a defined zone only, nothing else (i.e. no recording, etc.)
Monitor 2: linked to Monitor 1, will start recording (main stream) if triggered by motion detection on Monitor 1
I‘m quite a newbie and I’m puzzled a bit in finding the correct settings for Monitor 1 and Monitor 2, with regard to Capturing and Decoding in 1.37?
There's likely something in the wiki. I don't use triggering, so I trust someone else will point you in the right direction. Have fun...
@jsengjensg wrote: ↑Wed Aug 09, 2023 10:49 am Happy to explore it But I‘m wondering what‘s the correct setup in 1.37 for the following:
Did you ever resolve how to use the MoDect/NoDect setup with 1.37?
I am looking to upgrade to 1.37 from 1.36 and have all my cameras setup the way you described. Each camera has two feeds:
- Low-Res stream with MoDect set
- HiRes stream with NoDect set, triggered from Events on the LoRes stream
Did you figure it out or find docmentation to help?
Richard
1.37 on Debian 12 (bookworm)?
I expect the answer to be "No" but in case there is a way, I thought I'd at least ask.
Is there a way to install/upgrade to Zoneminder 1.37 if I am on Debian 12 (NOT Ubuntu)?
The PPA for 1.37 lists kinetic (Ubuntu 22.10) as one of the install options for 1.37 and kinetic is based on bookworm (Debian 12) so I thought I would try it but, after installing the kinetic PPA and update/upgrade, it ended up giving me about 10 "Cannot install" errors for libraries that are required for installation of Zoneminder 1.37 but appear incompatible with Debian 12
So, is there a way to install/upgrade to 1.37 if the server is Debian 12 (bookworm) based?
Use packages at https://zmrepo.zoneminder.com
jensg wrote: ↑Wed Aug 09, 2023 10:49 amHappy to explore it But I‘m wondering what‘s the correct setup in 1.37 for the following:dougmccrary wrote: ↑Wed Aug 09, 2023 8:47 am It's worth exploring.
(previouslyy posted this Q but used the wrong tag for @jensg, sorry; guess that explains why no reply ... )
I have now installed 1.37 on a test server but with 1.36 have all my cameras setup the way you described. Each camera has two feeds:
Based on the responses above, it does not sound like this is the normal (or event supported?) setup in 1.37 but I cannot find the documentation for what to do differently in 1.37.
Did you figure it out or find documentation to help?
