New zmNinja release for Android
We have a new version (1.7.000) uploaded to internal testing
If you are interested in early access, say so, provide your email address (that you log into Play with) and we will add you.
Re: New zmNinja release for Android
The new release is now generally available.
Kudos for the update! Unfortunately, Android 14 is now running some of our phones so I can't load zmNinja on my Pixel. Hopefully the next release of zmNinja isn't too far out and the toolchain is updated to build for 14.
1.7 release works on android 14.
There are issues with notifications though. We are working on it.
Ah, you are correct. I don't know what the issue was when I tried it last night, Play said not compatible with my phone. I've installed it now and will be giving it a try when I finish configuring ZM after my cameras get here.
Thanks!
Thanks!
Latest release 1.7.002 should fix notifications
Hi, Just downloaded zmNinja from the Play Store to my phone and it is showing Version 1.6.009 not the latest 1.7.002
Any ideas ?
Thanks in advance.
Any ideas ?
Thanks in advance.
You downloaded zmninja-pro.
Thank you.
I've installed the new version but I don't have any montage or images available, the older app has worked decent.
Double check your config. Montage and images work fine for us. We are aware of problems with the wizard and expert mode of configuring it.
Hm, my config shows the same paths as it did before, I'm not sure.
Thanks for all the effort you've put into these projects.
There are new desktop packages available at github now.
https://github.com/ZoneMinder/zmNinja/r ... g/v1.7.002
Gracias..!!
Play store shows me zmninja for $4.99 and zmninja pro as installed (I've had the last old reliable 1.6 installed forever it seems).
Is the $4.99 version the new update?
Confused....
BTW thanks so much for your tireless work on ZM.
Confused....
