looking for hardware recomend for affordable outdoor security
something that mounts in such a way to to show the vibration of door slams.
also are the mics in most cams pretty good or some better than others ?
perhaps a seperate amplified mike maybe?
cameras mounts to show vibration
Re: cameras mounts to show vibration
That might work with the microphones. Interesting idea. I don't know if you'd see false alerts.
Arduino is always an option. https://wiki.zoneminder.com/Arduino Some cameras have IO connectors you can tie into. Or you can use zmtrigger.
This is probably a niche use case, so I don't know how many folks have done anything similar.
fastest way to test streams:
