Decoding is not keeping up. We are xxx seconds behind capture.
R0yk3
Post by R0yk3 »
Playing around with my system, and saw that the automatic purge is not working. so turned on the log's to debug. Not finding the answer why the purge does not start automaticly, yes Run filter in background is ticked.
But i also saw the message as in the subject:
I thought my zones where not right, but i guess this is the problem that not all motion is recorded.
Is there a quick fix like give more memory or something.
The system is running within proxmox on a debian image with 8 gigs of ram and 4 cpu's
i have 4 camera's
#1 in record mode in low res permanently.
#1 in modect hi res.
#2 in monitor mode hi res
#3 in monitor mode hi res
#4 in modect mode hi res
:roll:
BB7Networks
Re: Decoding is not keeping up. We are xxx seconds behind capture.
Post by BB7Networks »
Lower resolution and lower framerate can greatly reduce the load on the server. I see 'Official' security camera companies install a decent camera, then limit the framerate to 10fps.
In my own ZM configurations, I set the framerate to 5 fps.
You're running Debian, would be worth using htop to see how slammed your system is.
