Unable to see video on ONE computer
I have no problem logging into ZoneMinder on my laptop and viewing live video or playback of events. My wife's computer on the other hand can log in but just a large, blank, white space where the video should be. She has tried it on several different browsers (Chrome, Edge, & Firefox). I am at a loss as to why video is not playing back. I was able to take a brand-spankin' new laptop and log in and view video, just not on my wife's desktop. Can you think of anything that might block this across the board on just one machine? I had her log in using my administrative account too but it still didn't work. This is very similar behavior to me using an iOS or Android device, as ZoneMinder apparently doesn't work with mobile devices any longer but my issue is on a Windows 11 desktop.
Re: Unable to see video on ONE computer
You don't say which version of everything, but around version 100 of chrome and firefox, they changed something about img display and I had to spend a fair amount of time figuring it out.
If you aren't on 1.36.32 and the latest browsers, update.
Weird. Today was the first day I *NOTICED* that my videos have stopped playing on all my PCs except one single laptop. Now I am wondering why it still works on my primary laptop but from no other device. I tried numerous other computers that I've known to work in the past and on nearly every browser.
The machine running Zoneminder is operating on Ubuntu 22.04.01 on a 12th generation i7 CPU and 64 GB RAM. From other borkings on another machine, I have learned NOT to do full-upgrades and only do standard "apt upgrade". I am running 1.36.32.
With the possible exception of windows 11, which I don't have, all those should work.
Maybe try clearing cache on the 'broken" machines?
I see zm working on iOS and 'Droid, phones and tablets.
Right click on where the image should be, click on Inspect.. Look at the css styles/properties of the img tag and surrounding Divs...
same here. no issue on win, mac, phones, tablet. through the internet browser (*) and/or the proper version of ZM Ninja (**)dougmccrary wrote: ↑Fri Jan 27, 2023 11:01 am With the possible exception of windows 11, which I don't have, all those should work.
(*): warmly suggested mozilla firefox
(**): warmly suggested on mobile (iphone, android) and tablet
if you have more than 6 cameras, please let us know.
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
I just realized the error in my ways. It has to do with network security/domain names/ports... "Multi-port setup". The reason it was working on the one computer was related to my domain being placed in my local hosts file.
that's the reason I wrote "if you have more than 6 cameras, please let us know."
While I now know the gist of my issue, I'm still having some issues finding the solution to my issue and it is most likely in my router/firewall. I happen to be using pfSense. I use HAProxy and a domain name to direct web traffic to my ZoneMinder interface.
I currently have 12 cameras connected on ZoneMinder and all but one, I have created two monitors per camera. I create two monitors, one for the high-resolution set to "Nodect" and the other one set to "Modect" I call the "Modect" cameras my trigger feeds and they trigger the high-resolution monitors to record. Following the instructions for Multi-Port setup, I set up ports "30000-30050" to be used.
Earlier today, when I realized that this was the source to my issue, I tried to set up port forwarding. In pfSense, you can create aliases for ports, so I created a port alias I called "ZMPorts" for "30000:30050". I tried to create port-forwarding and didn't know what type of ports these are supposed to be. I assumed that their protocol would be either TCP or UDP and there is an option for redirecting either of those protocols on those port numbers to my ZoneMinder machine but it doesn't seem to work. Could they be some other type of protocol besides TCP or UDP?
I realize that some of my issue is with something other than ZoneMinder (pfSense) but the issue is co-related with ZoneMinder. Should I ask a question in a pfSense forum, they would likely say that it was a ZoneMinder issue... a chicken<->egg scenario.
It’s not so much a ZM matter, but all the complications that have been layered on top.
Set up your ZM multiport then netstat on the machine to see the 300xx ports. Verify they are TCP.
I had not previously played with netstat but I learned something interesting. I see that all these ports are TCP6. For example, I see rows like:
tcp6 0 0 [::]:30005 [::]:* LISTEN
tcp6 0 0 [::]:30006 [::]:* LISTEN
tcp6 0 0 [::]:30007 [::]:* LISTEN
tcp6 0 0 MY_DOMAIN.NAME:30001 10.1.15.2:26613 TIME_WAIT
tcp6 0 0 MY_DOMAIN.NAME:30012 10.1.15.2:26605 TIME_WAIT
tcp6 0 0 MY_DOMAIN.NAME:https 10.1.15.2:26584 TIME_WAIT
I have never spent much time getting to know the ins and outs of IPv6, which is why I'm a little confused why it is showing from my domain name to an IPv4 IP address. Is my issue somehow a routing issue because of involving IPv6? I don't see any of the 30000-30050 on standard "TCP", only "TCP6".
