Russian translation
If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
sef1976
Russian translation
Post by sef1976 »
I full translate 1.24.2 to rus
http://deka0.office-on-the.net:8080/zm/ru_ru.php.tgz
if need translate it to Ukraine lang
Isabella8688
Re: Russian translation
Post by Isabella8688 »
Thanks you for sharing.
mr.graf
Post by mr.graf »
The translation into Russian language in UTF8 encoding, as well as lots of useful information about configuring and installing ZM on the our forum in slackware.su
Started translation into Russian language of ZM options. Welcome! :)
mr.graf
Post by mr.graf »
The translation ZM 1.30.0 to Russian language in UTF8 encoding is finished. You will have options, help and interface in Russian. How it make you can read on our website http://slackware.su/forum/index.php/topic,2740.0.html
SteveGilvarry
Post by SteveGilvarry »
And thanks for using your signature for feeble attempts at SEO, Deleted
mr.graf
Post by mr.graf »
The Russian translation of the options, help and interface for ZM 1.35.*, as well as a description of how to use the translation, can be found here .
And as well as lots of useful information about configuring, building from source code and installing ZM in Slackware Linux on the our wiki. Welcome.
mr.graf
Post by mr.graf »
The Russian translation of the options, help and interface for ZM 1.36.*, as well as a description of how to use the translation, can be found here .
