Get latest Frame (jpg) from camera?
kibbling
Post by kibbling »
Sorry for my newby question. I tired each documentation, but can’t find:
How can I extract the latest Image of a camera as jpg, in order to upload it to my homepage (each minute)?
I use “Record” and write all cameras all the time without images (because of the space) to disc.
I found the URL
http://IP/zm/index.php?view=image&fid=2251&eid=14&show=capture
where I can capture each Frame from the stream. But I only can guess, what is the latest frame. So currently I guess the frame number by the walltime modulo the FPS.
Any tip for an URl to geht/extract the “latest” frame , in order to upload it each minute to the website?
I have not managed to figure out what is the “connkey” for the live URL, think this is somehow a “secret”? Maybe a way to bypass this connkey?
http://IP/zm/cgi-bin/nph-zms?scale=75&mode=jpeg&maxfps=30&monitor=1&rand=1665146563&connkey=637539
Re: Get latest Frame (jpg) from camera?
How about video instead?
Set up a basic user with view only permission. I use user with a password of user. I also set up a low res cam with monitor function.
Here is the code to put into an html file:
<html>
<meta http-equiv="refresh" content="300">
<body>
<img src="https://your.url.net/zm/cgi-bin/nph-zms ... &pass=user">
<body/>
<html/>
Your Zoneminder server will need to be port forwarded through your router. Note the monitor=4 is the cam ID from the Zoneminder cam list.
Have a look at zmu to grab a frame.
If you look at the console with thumbnails, that is an example of how to get the latest jpeg.
The gist of it is http://hostname/zm/cgi-bin/nph-zms?mode ... &monitor=1
You can add scale= or width= etc. You will likely also need to add authentication if you have auth turned on. So user=&pass= etc.
The view=image stuff is really for getting event frames.
Also as mentioned, there is zmu.
kibbling
Post by kibbling »
Thank you all.
I found only this workaround until now. Everything else is a mjpg and not a jpg.
curl "http://IP/zm/cgi-bin/nph-zms?mode=jpeg&monitor=1" -m 1 > out.mjpg
@iconnor:
Thats also MJpg not jpg.
@Magic919:
What is "zmu"? Where to look at it?
@bbunge:
Thats not possible. Need to push lots of Cameras through very small internet connection.
Also dont want to open a port from extern to this network.
So it needs to be "push", not pull. And need to have very small amount of data.
ZMU is part of the ZM install. Run zmu -h for some clues. You'd usually specify monitor number, user and password.
kibbling
Post by kibbling »
Thank you, thats great. Think "zmu -i .. -m..." do the trick!
Sorry I typod. It should be mode=single not mode-single. mode=jpeg is mjpeg mode=single is a single jpg.
kibbling
Post by kibbling »
Thank you, this is also working!
Very helpful here, thank you all!
burger
Post by burger »
This works well. Here's an example webpage that reloads the image w/js every couple seconds in case anyone is interested.
The zmu I put in cron.
<head>
    <title>Camera</title>
    <script type="text/javascript" >
setInterval(function() {
    var myImageElement = document.getElementById('myImage');
    myImageElement.src = 'Monitor4.jpg?rand=' + Math.random();
}, 5000);
    </script>
</head>
<body>
<h1 style="text-align: center">Camera <a href="URL">URL</a>
<div align="center">
<img id="myImage" src="Monitor4.jpg" />
</div<
</body>
fastest way to test streams:
