ERROR: Conf zoneminder does not exist!
Cosmograph
Post by Cosmograph »
When I try to configure the apache2 with "sudo a2enconf zoneminder", I have this issue : "ERROR: Conf zoneminder does not exist!"
I am in Ubuntu 22.04.1
Any idea ? Thanks a lot !
Re: ERROR: Conf zoneminder does not exist!
Have a look for it -
ls /etc/apache2/*-available
It might be under /sites-available. If it's not there at all you have a bigger problem.
Cosmograph wrote: Fri Sep 23, 2022 1:10 pm Hi,
Here are install instructions for Ubuntu: https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.36.x
Note: Ubuntu 20.04 works better for me than 22.04.
Cosmograph
Magic919 wrote: Fri Sep 23, 2022 1:24 pm Have a look for it -
Hi and thanks,
Under /sites-available I have only :
"000-default.conf default-ssl.conf"
What kind of bigger problem ?
Impossible to say.
What was the output of the command?
Have you tried the install instructions above?
