Repeated error message:
jogo
Post by jogo »
I am getting repeatedly error messages related to a certain camera like
Jul 06 13:15:05 <redacted> zmc_m4[2230]: ERR [zmc_m4] [Error writing packet: Invalid argument]
Jul 06 13:15:05 <redacted> zmc_m4[2230]: WAR [zmc_m4] [non increasing dts, fixing. our dts -4241066805 stream 0 last_dts 50175740]
Jul 06 13:15:05 <redacted> zmc_m4[2230]: WAR [zmc_m4] [pkt.dts(50175740) must be <= pkt.pts(-4241066805).Decompression must happen before presentation.]
I am not sure whether this is related to Zoneminder or the camera, which happens to be one of the more expensive Hanwha cameras. Other Hanwha cameras do not produce these messages (afaik).
Re: Repeated error message:
There was a similar sounding thread recently. Think it was the ffmpeg version behind it in the end.
Vit-Lucius
Post by Vit-Lucius »
Good time of day.
I had exactly the same error with 4 cameras. The program version is 1.36.33.
9/15/23, 11:48:21 AM GMT+8	zmc_m24		42622	ERR	Error writing packet: Invalid argument	zm_videostore.cpp	1425
9/15/23, 11:48:21 AM GMT+8	zmc_m40		42653	ERR	Error writing packet: Invalid argument	zm_videostore.cpp	1425
9/15/23, 11:48:20 AM GMT+8	zmc_m23		42775	ERR	Error writing packet: Invalid argument	zm_videostore.cpp	1425
9/15/23, 11:48:20 AM GMT+8	zmc_m23		42775	WAR	pkt.dts(35364600) must be <= pkt.pts(35363700).Decompression must happen before presentation.	zm_videostore.cpp	1409
9/15/23, 11:48:20 AM GMT+8	zmc_m23		42775	WAR	non increasing dts, fixing. our dts 35363700 stream 0 last_dts 35364600. reorder_queue_size=0	zm_videostore.cpp	1398
9/15/23, 11:48:17 AM GMT+8	zmc_m22		42628	ERR	Error writing packet: Invalid argument	zm_videostore.cpp	1425
OS Debian 12
ffmpeg version 5.1.3-1
IP Camera: IPC-HF3500
Encode Mode H.264
Resolution 3M (2048*1536)
Frame rate(FPS) 15
Bit Rate Type VBR
Quality 6(Best)
Bit Rate 8192
I Frame Interval 30
In ffmpeg 4.8+ we started seeing out of order packets coming from decoding. Problem is when writing out to mp4, they need to be in order. So we now need to buffer them and sort them.
You can set a parameter in Encoder options, reorder_queue_size= to turn on this buffering. Testing seems to indicated that for most people setting it to keyframe interval or 2*keyframe interval should do.
In 1.37 we automatically detect the need and size, but in 1.36 you have to set it manually.
pat2
Post by pat2 »
Hi Isaac,
thanks for your strong job.
Please, note that in the "proposed" repo 1.36.34 version is not available for jammy, focal, bionic, xenial.
Something went wrong in the build process.
thanks
ZM 1.36.34 - 14 cameras on Orange Pi 5 (arm64) - Ubuntu Jammy 22.04
Ok, I have a few more fixes in there now, will push another release
pat2
Post by pat2 »
iconnor wrote: Mon Sep 18, 2023 1:54 pm Ok, I have a few more fixes in there now, will push another release
upgraded !
thanks
phuongpham
Post by phuongpham »
pat2 wrote: Fri Sep 15, 2023 4:01 pm Hi Isaac,
thanks
When will this fix be released?
ZoneMinder Proposed - Ubuntu Jammy 1.36.34~20231031.12-jammy1 2023-10-31 None
( from https://launchpad.net/~iconnor/+ppa-packages?batch=75 )
