how to reduce cpu load?
Re: how to reduce cpu load?
how much it hung, did a hard reset. No such problems were observed.
and iotop does not see problems in hdd
At night, the CPU load drops, then grows again. while the traffic does not drop
What is server kur?
Do you have ecc memory? if not, have you tested it recently?
Do you have video acceleration available?
Is your database in an ssd?
I have several servers, the base is separate, on ssd.
server kur - problem server.
memory - before: 2*R748G2133U2S-U ; now: 1*KVR26N19D8/32
no
Memory Device
Array Handle: 0x0028
Error Information Handle: 0x0034
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Bank Locator: P0 CHANNEL B
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 2667 MT/s
Manufacturer: Kingston
Serial Number: 20503ACD
Asset Tag: Not Specified
Part Number: 9905734-100.A00G
Rank: 2
Configured Memory Speed: 1333 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
no
So not ECC. Just to be sure, I'd run a test like memtest86 a couple passes.
I habve the same problem with 1.36. all 4 Cores are at 100%…with 1.37 ist comes down a bit. I use bullseye. Zm stopped the machine is at 25%, with zm started immedialtely at 100% no matter Cameras are disabled or in Monitor.
That seems high. What's it doing?Zm stopped the machine is at 25%
Smbd, Openhab,vzlogger,grafana,postgre
When i run shinobi only one Core is at about 80%.
updated to .19 immediately ate all the memory and the server hung. reverted back to .11
Just a shot in the dark but how are your CPU core temperatures in the daytime? Is it throttling due to heat during the day but then cooling off at night?
It's not about temperature.
Here is the monthly schedule. After rebooting the server, the cpu became under 100, before that it worked by half.Re: how to reduce cpu load?
it's all about memory. He returned what was standing, the CPU load returned to normal 40-50%. I put a new one, cpu 100%.
the problem was solved by replacing the memory with 2 * R7416G2133U2S-U
CPU usage is back to 40-50%
